Do grid switches work with dry lining boxes or do they require grid switch back boxes?
Cheers, John
Cheers, John
you get the same problem with all dry lining boxes.. sockets don't sit fluch either..
you're supposed to fit them before the wall is skimmed.. the plaster makes up the difference..
if you're retro fitting, score round the box with a knife and use a wood chisel to scrape a layer of plaster away so it sits flush.. ( usually said skim, but you can dig into the board too.. )
your 'avin a larf, talk about a pigs ear.
