grill trips rcd
In the first instance I would be tempted to conduct an experiment replacing the thermostat with a normal switch (taking all safety precautions including making absolutely sure that the oven did not overheat!!!)
But just in case, make yourself a Neapolitan pizza ready to take advantage...
As evrything works ok if the thermostat contacts are closed before the live is connected
But I thought you said that the RCD tripped when the thermostat re-opened? ie it was only OK while the thermostat was closed.
Have you tried the experiment yet?
Do rcd operating values change ?
Not as far as I am aware. You can use an RCD for calibration purposes over a period of time implying that it does not change.
