Hi everyone,
I am having some work done in my kitchen which are additions and alterations to the existing ring main. The house installation has a Wylex rewirable type consumer unit with a sperate downstairs and upstair ring main, the main earth to the water stop cock and gas valve is in 6mm. The sparky states that any ground floor socket that may be used to take an extension lead outside needs to be RCD protected. He does not want to change the CU but says he will add an inline RCD. Firstly can this be done as you would have (as i see it) a rewirable fuse carrier feeding an RCD. Would it not be better to run new tails from a phase block to the mini RCD board and then have the output off that. It all sounds a bit confusing thank god i only work in Millivolts.
