you have had a lot of good feed back here with loads of good guys with loads of good experience. my opinion, well geo thermal is a great theroy, suppose to date back to roman times when they had fires under ground heating running water. it doesn't use any fosiel fuels? well it is essential that it has a 3 phase 415 volts power supply for a start. the same electric requirements for a small engingeering or industrial workshop. etc. and thats just for a house
the cost of a local electrical supplier to take 3 phase to any dwelling intatially in costly never mind running a 3 phase underfloor heating system, running at low temperature 24/7
well if that isn,t using fuel from some where well
and the best bit is that because geo only achives temperatures of 30 to 45 degees c it can't heat ur domestic hot water so u r reliaing on electric immerions to heat ur cylinder for hot water. the big key the geo thermal is in the insulaltion of the dwelling. building sound cavity wall with heavy 50 mm foiled back insulation and then studding the insude walls with drylining and putting insulation in that again
an awful lot of bother. i have personally been to a lot of houses lately and reinstalling a standard oil/ gas heating system for one of thses geo thermal unit.
