Have a look at Bauder website to name 1. It was invented after the war to line reservoirs in Germany, and was utilised for flat roofing as a result. There are roofs 50 years old in it and totally fault free. We charge from £95-£180 ish a m2 depending on build up. Inclusive of prelims.
Cold adhesive had a run in the 80's and to be honest, i've not seen it let go on the field area, but have on the laps. Its also a complete bastard when stripping, think bitumen in 100 degree heat. Most bitumous systems are self adhesive with welded lap and torch welded cap sheet, unless green roof then fully torched.
We stripped Brent Cross in the 90's, 50,000 m2 of Butyl roof that had failed after 7 years, on every lap. The reason being the combined thickness of the lap had a different thermal movement to the flat, and rippled itself apart. Thats why single sheets cut to project are fine, but once you get over a managble size, joints are introduced, and it fails.
