GWS vs Reliance - Accumulator
30 Jan 2013
London
Does anyone have experience of either of these?
Reliance – Aquasystem 500 Litre Potable Expansion Vessel XVES050150
£660
GWS Challenger 450L Accumulator Tank
(same as Stuart Turner Mainsboost 450SV?)
£690
Both are similarly priced.
The reliance has a replaceable membrane.
The GWS has a 5 year warranty.
Mainly thinking about longevity, rather than performance (which I assume will be identical).
If it's longevity then the one with the replaceable membrane would seem to have the lead, unless the cost of the replacement membrane is prohibitively high. It may be worth also considering that a ruptured membrane would expose the mild steel casing to oxygenated water,so if that rupture isn't found and rectified quickly then the subsequent rusting (and rough surface) may cause rapid wear of the new membrane.
I wasnt able to find an online price for the replacement membrane.
I'm inclined to think the GWS has better marketing behind it and essentially is the same as the Reliance (they talk about patents related to better design - but does it translate to better longevity in reality?).
Someone must have experience of either of these - how long has it been in operation, and have you had any issues over the years?
