OK, if there isn't enough pressure or flow to feed one electric shower @ peak demand then your peak dynamic pressure and flow is extremely low, especially if has then at least 5-6m head to overcome to get to the 2nd floor.
IMO though an accumulator is not the answer as it will run out of puff in no time at all especially with a 300L unvented @ peak use, then it falls back to a 12L/Min max flow as that is the limit when it comes to mains pumping.
The stored pumped booster set system is much more effective and provides a much larger storage capacity which your property will need to supply both hot and cold at a suitable pressure across a range of outlets. That storage is then delivered to the whole house at a consistently high pressure and flow as it is independent of the mains.
of course this is all guesswork as none of us are on site and don't have the benefit of that 1st hand knowledge. That being said I would bring these concerns to the professionals who are and ask if there is a risk that the accumulator could be exhausted quite quickly and what the fall back is when that happens. The ST Variboost, is not designed to pump from mains, it is designed to pump water from a cistern (like a booster set). The accumulator is not a cistern, so once the volume in the accumulator is used up, what would the variboost be drawing directly from .... the mains? That could be fraught with problems, not least the impact to the mains supply to the neighbourhood. Are your mains metered? A few questions, I would suggest need answered
