I've just tested an FX100+ panel V3.51 Ethernet A083-00-02 with the app driving the outputs via panel outputs and via trigger module. I set control to enabled and toggle or trigger and everything worked as expected. Are you programming the output control as 'toggle' if you want the output latched via the app ?
Also, yes you are correct. You cannot control trigger module outputs via the app. I would add a RIO board for robust zone expansion. The trigger module is really only designed for digi modules. I've recently had issues with a trigger module being susceptible to electrical noise from the bell and strobe lines. It caused the trigger module to sound the siren continuously when a customer switched on his kitchen lights.
