What thickness of ply was used? If the ply board itself is moving you have a far more serious problem; it’s either not been built properly in the first place or the surface plies under the tile have already rotted. Can you not get someone to push the front while you look at the back behind the studding?
Either way it’s got to come off; it’s probably the grout holding it in place, rake it out & see what happens, a little encouragement with a flat scraper will help you extract it in a controlled fashion.
To my horror, our normal shower also appears to have a hole on it .
Please remind me what's the best board to use on stud walls in the shower?
Thanks.
Since posting it, I found Richard's other postings. Aquapanel is what you are recommending for this task?
One more question:
If the stud wall meets a brick wall on one side, how do you close the gap between them? Do you need to something special or tiling over them would cover it?
