Hi, I've rigged up some ad hoc lighting for the purpose of photographing items for a website. I'm using three B&Q £4.99 500w halogen flood lights. I'm running two off one 13amp wall socket (ie off off a twin socket extension lead going into the wall socket and the third off another seperate 13amp wall socket.
My query - I've been told I can use a dimmer with these lights and need to know if this true or not! A dimmer apparently as in something you plug into the 13amp socket into which I plug in the 3 pin plug from the lights.
Can I use such a "plug in" dimmer with one light?
Can I use such a "plug in" dimmer with two lights running off it?
btw These lights run for 10 minutes at a time and are never left on unattended. I'm assuming this lighting set up though not usual is ok for temporary use???
The 3 pin plugs are fitted with 13amp fuses. What is the correct fuse rating to be used with these lights in this way?
Hopefully I'm not now going to get a dressing down for what I've been doing or what I want to do
