Thanks especially to tinymole but also other contributors for helping me repair a Halstead Best 60db boiler which had been behaving intermittently, on the first visit springing into life without me being able to resolve what the cause was, on the second failing to exhibit a problem, on the third appearing not to work due to a slight water leak, then working when dried out.
Today, the boiler refused to work, making diagnosis easier! On heating demand, the pump started and there was a periodic click from the boiler (perhaps every umpteen seconds, just as on the first visit) but no fan. Based on previous help from tech support at Dimplex (who themselves I believe have stopped doing gas boilers), I knew the overheat stat was ok (short, not open circuit), that the thermistor was ok (resistance above 1 megohm), that the fan was ok (resistance around 40 ohm) but wasn't being powered. Everything pointed to the gas valve/ignition module, which I couldn't get into on-site.
I placed an order for a new one, then viewed this forum which gave me the confidence to get into the module (not easy, the main thing being to free the black spade connection section using a scalpel). It was immediately apparent that the track around one of the relays had been eroded away to the point where one pin was definitely isolated and another suspect. I guess that the copper track reached the point where connection was intermittent, then finally gave up, due to the current being carried, acting like a fuse. Whether there was a manufacturing defect at the start, I can't say. There was no sign that moisture had caused the fault, so I believe the water drips were a separate issue. That relay powers the fan, which explains why the fan didn't run, and I guess the clicking of the relay (the low voltage section which operates it was fine) was due to lack of response from the fan pressure switch.
Repair was possible using solder, but for good measure, I added enamelled copper wire links. When the unit was put back in the boiler, it sprang into life, avoiding the need for an expensive new module.
Thanks all. Ian B gas (538432)
www.ianbgas.co.uk
View media item 56746 View media item 56747 View media item 56748[/url]
