Red dust means you have drilled into brickwork! You'll get a good fix into that.
Assuming you have used the correct drill, the plugs should gently tap in - but get rid of the dust in the hole first!
To shift an old plug, pop in a woodscrew a little way and tug the whole lot out with pliers.....or simply drill straight through it.
John
John
