Sony Handycam DCR-SR70EDo you have the make and model?
Thanks. I'll give it a week to dry out in the airing cupboard then see if a miracle occurs when I power. Most likely not.The salt water will have probably caused short circuits which could have fried the main board.
There is a possibility the hard drive will still work however it will entirely depend on how much water got in and what state it is in.
You could take it to pieces and take the drive out however unless it is a SATA connection which you could hook up to a PC via a SATA to USB cable, you may be screwed as it is often hooked up with a flat cable straight into the drive which would make things more difficult.
Lovely little cameras at the time, I used one extensively at work.Sony Handycam DCR-SR70E
Excellent, thank you.Lovely little cameras at the time, I used one extensively at work.
Apparently they use drives with a ZIF (zero insertion force) connector:
ZIF to SATA, or USB adapters are available.
Its already been soaked in salt water several days ago, I would suggest any damage has already been done. As a sailor (there is a clue in my user name) anything that gets dropped into salt water needs rinsing in fresh. By all means take it to someone who can repair or try to recover the data but I am offering genuine diy advice.
Take it or leave it, no skin off my nose
