Anyone advice on the factory reset process on a Haus WQP12-950G.
The dishwasher shared a cold feed with a washer via a 'Y' splitter that decided to bounce itself out of its slot, lock the drum up, bust the door off and snap the inlet pipe off and flood my sisters kitchen.The d/washer was on mid cycle at the time of the incident.
I understand they have a lock out/shut down safety feature to protect the dishwasher if there is now water.
The d/washer is now showing the flashing rinse light which is the fault code for overflow problem or water leak from appliance according to the manual. It pumps out ok when I pour water in direct but wont allow water in as if the water inlet valve is closed still and doing as it should to protect the d/washer.
I wanted to try a factory reset or any other process to assess if the machine is damaged permanently and get it replaced on the insusrance.
