I have the house jack built.
I have tried the simple task of replacing switches on a lighting circuit. I have tried to sort out a faulty 2 way switch.
I firstly swapped the switches making sure all connections were like for like. I have a ground floor switch operating a landing light. This connects with a double switch for the bathroom and landing on the 1st floor.
The bathroom light works upstairs, the landing light works from downstairs but I can't get the landing light to work from the upstairs switch.
The downstairs switch is a standard two way switch. It has 4 core, earth Red Yellow and Blue.
Yellow(Y1) is Common, Blue(B1) is L/2 and Red(R1) L/1
On the double switch the bathroom switch had Y1 in L/1 with a Red wire(R2) going into a new feed(believe this is bathroom supply), the Black related to this supply was at L/2 on the bathroom switch as was the Blue (B1) from the hall feed.
The Red wire(R1) from the hall switch was connected to the common terminal on the landing switch. Also on this switch was another feed(believe this to be landing light supply), with the red wire (R3) at L/1 and the black wire(B3) on the common terminal of the bathroom light switch.
does this make any sense to anyone.
