I have a hot water cylinder which is heated by te gas boiler (not a combi) and yesterday the overflow started running although only slowly. It has run overnight despite the heating being off.
I'm sure its the hot water expansion not the header tank for the rads.
I've been into the loft and the tank is full, there doesnt appear to be cold coming in, the ball cock is floating and not even dripping. THe water is definitely warm/hot.
The fat pipe at the bottom of the tank appears to be letting the water is almost like its being pushed into the tank you can just see the water swirling.
Any help I'd be grateful.
Thanks in asdvance.
Thanks in asdvance.
