i would still fit the isolation valve.Right I have isolator valves either side of the pump. I take it then if I replace the isolator vale on the 'out' side of the pump with a non-return valve then it would stop this back flow and if I needed to replace/repair the pump then the non-return valve would stop the water coming out when I take it off.
whats this bit then about the pipes split from the bath ?Regarding the bath tap no it's not pumped. Because the tap is lower than the shower head it seems to run OK albeit a bit weak. It would take a long time to fill the bath though.
(where the isolation valves are (compression fittings) just after they split from the bath feeds,)
that would be a better solution if you can strip it down as the non returns means the mixer will have to be disconnected in the wall and come out to free the valve.Don't bother trying to fix the mixer then
what make/model mixer is it ?
Is this a common problem?
quite common.
but then its not ideal to have you mixer on mains cold pumped hot.
work better on equal pressures.
whats the height distance from your head to the base of the cws in the loft ?
