Whenever boiler fires up, hot water or heating, overflow occurs. Not just a drip, more like a running tap!
I have replaced ball cock and checked that the valve does not leak. The hot water thermostat appears to be working (when knob is turned it clicks at various places on dial, depending on temp. and boiler fires up!) Heating is OK all rads hot (bleeding not required) so I assume pump is ok.
What else can I check/test?
Any sugesstions gratefully received.
