oh s**t not a tradesman he will catch us out
davidf said:2. When the pump is running, water flows continuously UP the expansion pipe from the header tank.
3. Pump changed about 2 weeks ago.
Is there anything else you need to know?
We need to know the sequence of pipes from the boiler flow to the vent, feed and pump. There may be a blockage where the feed pipe meets the system.oilman said:...... we need to know where the feed pipe is connected to the system.
I can't adjust the ball valve - it's already as low as it will go.
