Header Tank keeps filling?
I got a long one in B&Q, it is about a metre long and cost about £15
Thanks but I just bought a long one on ebay for £7.36 (including P&P).
Gave up with the header tank and called in the pros... British gas quote Just a boiler: £4500, NPower complete full central heating system boiler rads (plus extra ones in other rooms) pipes fitting etc. £4900. seems quite reasonable fitting in two weeks....
Fit non-return valves on all hot & cold inlet pipes to taps/mixers
fitted a double check valve on the hot water shower and problem solved, thanks for your help, unfortunately the shower supplier did not put this in the instructions? :rolleyes:
