A novice here: just returned from Hols to discover water jetting out of overflow. After pondering where and why - its the cold water header tank float valve. It didn't cut off - so I consulted DIY book and identified need for new washer. After some time I installed this - and indeed the flow is now stemmed. However - the thing doesn't really ever cut off. I've tried adjusting the float (if I manipulate the thing it does cut off, but I suspect my manula pressure is more than the water?). Does this mean I need to replace the valve itself (ie the brass bit)? I do notice that the whole float valve is not quite at 90 degrees (so may be the pressure of the float is not effective. The question is then - how on earth do I work out what type of replacement valve I need (size etc)? The washers were easy because they came in a pack of 3! Or shoudl I just get a plumber to come?
