Just as an update.
I got the fire up and running over the weekend, had a small fire first then a big one with airvents open running at max power and measured the heat of the wall with a thermometer. As suspected it was alot higher than the crucial 49degC.
Do you think taking the plaster board down and then rendering the area is a beter option or should i put in a cement board on?
I am inclinted to go for cement board as i'm not great at rendering.
If i go for the cement board how should i fix it to the wall, what adhesive is best?
Also can cement board be skimmed relativly easlly with the vitcas heat proof plaster?
