Hi there, I have a Glow Worm Easicom 28 (not by choice). For the third time now my hot water temperature fluctuates, the first time it happened I had an engineer come over who done a complete power flush and said the water was actually quite clean, in fact when I was watching the water coming out, it was clear. He went around knocking the radiators with a rubber hammer and at best some black flakes come out during the flush.
He also checked the magnetic filter and although it had some black deposits, again he said it was pretty clean. Anyway, he took the plate off, put some acid into it and loads of black deposits came out which done the trick. Four months later we got the same problem. This time a Vaillant engineer came, looked at the magnetic filter and said water was clean with minimal deposits. He changed the plate for a brand new one and put in a new pump. He showed me the old plate and it was full of black deposits. This worked fine for over a year until last week, it happened again.
Had the engineer over again, he again looked at the filter and the water he had to drain and said that the system is clean. He took the heat exchanger plate out and showed me black deposits in there, he's cleaned it with acid and our hot water is fine again.
The question is, if my water is clear, I have a magnetic cleaner in there, where is this stuff coming from? Heating system has inhibitor in there, it was tested last week and showed to be adequate.
Any advice would be appreciated.
