So I am trying to do a heat loss calc for my renovation project. Im not sure if I am doing it right. Wonder if someone could help.
First off I am using Stelrad STAR App to calculate as it seems the most detailed.
It is a 1900 solid stone cottage, that I have insulated big time. 100mm Kingspan built in all external walls via a new timber frame. 150mm in between the roof apex, 100mm in the concrete solid floor, then a further 40mm under the self levelling screed. All windows are Argon triple glazed.
So questions.....
When I calculate each room, do I need to take into account U value of internal stud walls?
The cottage is about 150 sqm floor area, and calculations are coming in at about 14KW load? This seems very low.
I am keen to get this right as it will need an oil boiler and want to avoid short cycling as much as possible.
One last thing, its heated by all UFH in the screed. Does this make any odds?
Many Thanks
So questions.....
Many Thanks
