- Joined
- 6 Jan 2025
- Messages
- 2
- Reaction score
- 0
- Country
I currently have a heat only boiler connected to a gledhill unvented cylinder. It is currently set up with external expansion vessel on the cylinder (white), various valves, external pump and a small header tank which I think is known as a open vented primary system, this keeps the heating and tank coil loop topped up.
This heat only boiler is now dead, my understanding is that I have a few options:
1. Replace the heat only boiler with another heat only boiler (keeping valves, pump, header)
2. Replace the heat only boiler with a system boiler, I think this means that the pump and small header tank can be removed and the boiler itself will provide a sealed primary system. This sounds good but will require my current system to be slightly reconfigured. The benefits being that the bits removed are old and might need replacing soon anyway.
3. Replace the lot with a good combi, the house is 4 bed 2 bathroom, with unvented cylinder feeding two showers (2 adults, 2 kids).
Any ideas on what to do, it feels like a have a good system but it's old and the world seems to have moved onto system boilers. I think the setup I have must be a very early unvented system.
It may be also important to note the location of all this stuff:
Boiler is in the garage
Unvented cylinder and header is in the loft
Pump is in the airing cupboard, in the location where the original hot water tank would have been when the house was built.
Thanks,
Thanks,
