IMO it's all about what you want and what the mains can deliver.
Firstly it is key to know the cold mains dynamic flow and pressure before anything can be considered. You need to take the flow measurement from a full flow tap as close to the mains supply as possible, your outside tap should do fine and then connect a pressure gauge to say an appliance valve and run at least one other tap at the same time. Time filling a bucket over 1 minute and post the results. Try and take the readings at a peak time if possible.
Thanks. I'll get my plumber to come out and have a look. Don't worry not jumping in without seeing what will and won't work. The outside tap and the tap in the utility room is filling a litre jug is less than 4 seconds. Not as as good as my last house but seems ok.
