- Joined
- 27 Jan 2008
- Messages
- 25,376
- Reaction score
- 2,985
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
We have been using heat pumps for years, first I got involved with 1980 in Algeria. But walk down the streets in Hong Kong in the town and it is hotter than in the country, the heat pump must have loses, and to heat and cool clearly it needs a fan, as can't really move radiator up and down the wall for winter and summer use.
Many simply but motor in reverse to swap from cooling to heating, but it seems working in only one direction does work better, so many used simple elements for heating, only the cooling used a heat pump.
But if the unit uses 500 watt, then it must produce 500 watt of heat, on top of the heat it transfers. And so on a globule view, one must also include losses. Using 500 watt in the home direct from solar panels the loses would be very low, using it from the grid supply, then also heat given off from the cables supplying the home, and any loses in the generation.
Fact that I don't at moment get paid for power I put into the grid means the simple power produced - power used can't show loses, as no one knows what is produced, so there are simply no actuate figures on losses. All we can do is look at cost to buy power, so if average price is 20p per KWh then we can compare that to cost for oil or gas, both which are cheaper than electric, so either some one ripping us off, or there are massive losses supplying electric.
Oil and gas supplied using road transport is clearly heavily taxed, so we are paying an inflated price.
However the main problem is shortages. We saw the Winter of discontent, and how relying on electric is no good, I had mains gas at the time, and the heater simply would not work without electric, so when we moved, we made darn sure we did not need electric for heating. Last house had a 4.5 kW gas fire, this house an open grate and we can burn any solid fuel, we can also charge the batteries with solar, so even with no grid power we can get some heating.
Lose gas or oil then oil filled radiators can keep the house warm, even if expensive, but for those with heat pumps lose electric and you have also lost the ability to heat the home with oil or gas, OK in summer may still be able to cool the home, with loads of spare solar power, but can't heat the home. So only those already with electric only heating would be really looking at heat pumps.
How much the increase global warming is hard to work out, but how much of a problem we will have with lack of electric we already know, November 1978 to February 1979 James Callaghan and the labour party showed us in no uncertain terms not to rely on electric for heating.
