My central heating, installed by BG about 10 years ago, and maintained by them on contract, has a master clock on which I can set what times I want the heating on and off. It's set to be on from 7:00 to 22:30 every day, and off through the night.
For some time now the heating has been starting up at various times in the night, when the clock says it should be off. Engineers have made five visits, and their first reaction is always that one of the motorised valves is sticking open -- though I don't yet understand how its signal is able to override the clock. To date they've oiled the valves, put new actuators on, replaced the timer unit and, if I remember correctly, replaced the control board inside the boiler. On the last visit, the engineer installed a plug in the lead to the actuator he thought was the culprit, so I could isolate it next time the fault occurs, and see if the boiler then stops (thus proving the problem is with that valve).
Last night the boiler came on at 3:15, so I unplugged the actuator, but the boiler and pump kept going. So I switched off mains power to the system. When I switched it back on again this morning it's working okay again, as it always does!
Any ideas, please, that I can suggest to the next engineer that comes? Though I don't know how the control system works, it seems logical to me that if the problem is caused by a sticky valve, that would only stop it switching off at night, not make it come on in the middle of the night. So, what else could it be? There's a white box about 6" x 4" into which the actuator and pump leads go, which I thought was just some kind of distribution board -- could that have a part to play in the saga?
