The attached diagram is a representation of my hot water & central heating system.
In case it's relevant the boiler is a Vokera mynute 14e and the existing motorised valves are Myson MPE222's.
The problem at the moment is that the two room thermostats are not working correctly. I had also planned to add a different timeswitch to give me 7 day control and boost functionality but I never got round to it so that's in the mix too.
So I basically need to change the timeswitch/programmer and the room thermostats. Seeing as I'm going to this trouble I'd like to end up with some decent level of control so as to use the heating as efficiently as possible.
I was thinking of getting the following:
2 * programmable thermostats
1 * 2 channel programmer
The idea being that I can set up the hot water channel just to switch the boiler on/off when necessary and that either room thermostat will turn on the relevant motorised valve and switch the boiler on/off through the central heating channel which will be left on constant. I'm aware that, because of the system design, I will get the hot water on when the heating is on but I'm not certain if the extra work involved in adding a three way motorised valve is worth it.
Is this a good way of doing this? Anyone have any suggestions/opinions?
