I have an Ideal Mexico Super CF465 Boiler, Wilo Gold 60 circulating pump, Honeywell 2 port diverter valve ( V4034).
My heating is working fine but no hot water. I called out a heating engineer who advised it was the diverter valve. Cutting a very long and sad story short I ended up buying the valve myself and fitting it, I only changed the valve head not the valve itself.
I still have no hot water. The valve appears to be working fine. When the demand is for heating and HW there is no resistance on the manual arm. When the demand is for hot water only there is resistance. The pipework on both sides of the valve is hot.
I traced the hot feed upstairs in the loft to the tank and again the pipework is hot into the tank. Just below that is what i assume the feed to the hot water supply, this is cold. I also have a feed from the top of the tank to a power shower and that is cold.
I have checked the vent valve on the tank and no air just a trickle of hot water. I've contacted the original engineer and he can offer no advice, it is annoying that he can't be bothered to come and look despite the fact I have replaced a diverter valve on his recommendation.
Any suggestions or advice would be really appreciated.
