- Joined
- 2 Dec 2017
- Messages
- 2
- Reaction score
- 0
- Country
Hi
My combi stopped feeding the central heating last week, and only fires for hot water supply when both heating and hot water are both set to ON.
BUT if I turn hot water function off, then the central heating will work.
So I can manually switch between hot water and heating but not have both simultaneously.
If I select both to be on, then it will only heat hot water supply.
Is this a diverter valve problem or microswitch or something else?
A week before the problem started I bled the system a bit to add inhibitor as it had not been added after a previous system drain to change a leaking pressure top up valve. Then pressure topped back up between 1 and 2.
