I think the Ideal part number is 173537. But don't quote me on that.
Not sure about that matey
IDEAL MAINS SWITCH KIT 173537
Good point Mike, i believe the reverse of these controls are carbon based and can wear out over time.
Do not understand what carbon has to do with switch contacts.
Contacts are dome shaped. When the contacts come together, they self clean. When these contacts make or break, a spark occurs at the contacts. The size of the spark is related to type of load that is switched. Heavier spark equated to accelerated contact erosion. A point is reached when the erosion turns the dome into a flat disc at which point self cleaning of contact is not takeing place and sufficient current is not conducted. In extreme cases heat is generated and smoke emits- even localised charring takes place. Carbon (black soot) I suspect is a by product but not base material
Yes. There is a kit you can buy. Can't remember the details though.
