Hi - We have an Ideal Mexico 2 conventional boiler, basically we have had a few problems with the heating not coming on in the morning only. It is set to come on 3 times a day, but its only the morning when it doesn't come on.
We tried replacing the Programmer first, from a Honeywell ST6400C to its replacement ST9400C. This wasn't the fault - still have the same problem.
We can override the heating on the programmer and get heat if we need it its just bizarre that only the morning it won't come on. The programmer heating light is on, the thermostat is clicking, the pump is whirring but no heat.
We have just worked out the settings we have for heating and hot water have something to do with it as we have the heating and hot water set to come on at the same time in the morning, but different times during the day.
Heating 05.30 - 7.30 16.00 - 18.00 19.30 - 21.30
Hot Water 05.30 - 7.30 14.30 - 16.30 18.30 - 20.30
Last night when we went to bed we turned off the hot water on the programmer and just had the heating to come on this morning. This worked fine.
We now think maybe its the Honeywell 4073 3 way valve, I have moved the lever to Auto (I think it was in the middle) and will see what happens in the morning with heating and hot water set both for 5.30am.
One more point, the backlight on the ST9400C is on constantly, which is fine but it PULSES - is it meant to flicker on and off every other second or does that point to wiring maybe?
Any advice welcome!
Ian
Any advice welcome!
Ian
