- Joined
- 9 Mar 2016
- Messages
- 10
- Reaction score
- 0
- Country
Hi all,
I'm currently building a new utility room/workshop that's separated from my house by approx 10 Metres. The building is single storey with the following dimensions:
Utility Room: 3150x4900mm
Workshop: 4700x4900mm
Attic trusses provide some additional space above:
Shower Room: 2000x3300mm
Office: 5850x3300mm
Insulation is all to current building regs. i.e. Loads of Xtratherm.
My house uses an oil combi boiler that's badly in need of replacing (and will be) and my plan was been to run pipes underground to the new building. A few people have suggested this is a bad idea and that I should consider a stand-alone solution in my new build. The length of run, time it takes to get hot water through and loss of heat in the pipe all being excellent reasons.
This leaves me with a dilemma of what system to put in my new build. One salesman has recommended electric radiators (Rointe) and an electric water heater. Another thought this was a poor idea and a small oil boiler would be best. A third is suggesting two air-source heat pumps (one up, one down). My only real brief (beyond the obvious need for warmth) is that I get a decent shower, not a warm dribble! Total requirements are:
Hot tap in utility room (other appliances are cold feed only)
Hot tap in shower room basin
Shower
Heated towel rail
Heating of some kind in remaining three rooms
I have no access to mains gas, living in a small village in darkest Cornwall.
Any steers on solutions to consider or avoid would be very much appreciated.
Steve
Office: 5850x3300mm
Shower
Heated towel rail
Steve
