The hot water function of the heating in my daughter's 8yr old house was working fine until a couple of days ago although she had noticed a couple of months ago that the upstairs heating was not so good. With summer coming she stopped using the heating and only fired up the hot water a couple of times a day - with no problems. On Tuesday she flicked the hot water on (well she tried to) and the trip on the fuse board cut out. Resetting it and retrying to get the hot water function to work tripped it time after time.
Thinking it might have been a seized pump, I took it out cleaned it and tested it and it works fine.
The system has (some?) motorised valves and Honeywell controls.
I would be grateful for any suggestions as to what could be causing the problem.
It seems the timer has not been working correctly and in order to get the heating / hot water to come on it had to be manually advanced.
In addition, when only hot water was selected the radiators were getting warm - from reading other entries on this forum it appears that the motorised valve is likely to be the problem with this particular fault - so a little job to do there.
What I am struggling with is the cause of the tripping of the electricity - as soon as we try to advance (switch on) the hot water. Could it be the controller itself?
