Ideal classic ff250 tripping out on HW only
Hi
Flushed system with sentinel then added inhibitor,fingers crossed all seems ok,must have been sludged up.
Unless it was replacing the flux capacitor that did it.
Thanks all for your advice
Hi again
Would you believe the boiler is tripping again on hot water only (exactly as before) after 6 months of working perfectly.
Any ideas/thoughts would be greatly appreciated.
To come to a conclusion you should measure the flow and return temperatures at the boiler ( and then better at the cylinder ).
Its not possible to properly diagnose problems without scientific measurement data.
Tony
Hi
Money still very tight (unfortunately still off work) realise should ideally call engineer !
Wouldn't touch anything i shouldn't ! Just asking in case something obvious.
