Hi quite new to this so would appreciate some help if poss:
I have a Heatline C24, that first of all blew the fused spur beside the boiler. When I changed the fuse, the diverter valve actuator seemed to be clicking, so I took it off, cleaned it it and stuck it back on. There was a wee bit of water between the black plastic actuator, and the main body.
The clicking seemed to go away, but the boiler wouldn't flash up on either on the heating or DHW cycle.
Reset everything then the boiler started to flash up, then the fuses popped on the PCB after about 5 seconds.
Something is obviously causing the fuses to pop, but I'm a bit lost.
Could anyone advise? or Advise what to check?
