Thanks for the reply!!
Your probably right! This morning, before i read this reply, i rechecked the DV and put the old one back on (with new o ring bit) and i got CH but no HW. Then i noticed the boiler is firing up for about 30 seconds, doing the CH then it goes off for 15 seconds, then back on again! And my missus reminded me, bless her socks their always good at reminding you about something, that the boiler has been doing this for months now, we noticed it once while i was out in the back doing a bit of barbie cooking. So it seems it has been doing this for ages, but because we get hot rads i thought it was just the way this boiler worked!! And the HW was another problem that has just started to happen more than usual.
I will take your advice and check the plate heat exchanger, ive got some damn buster stuff here that my dad inlaw passed to me for unblocking my bath the other month i'm sure he mentioned using it to clear out his exchanger. Honestly, why the f would someone fit a system without flushing/cleaning it? Just plain bleedin rude it you ask me!
I work in IT building, supporting, fixing complex servers and if i put in a application/database/management/file server (virtual or physical) and didn't check it all worked correctly and had all it's updates/patches/security it would probably fall over with it's own version of "fitted without cleaning the system" its just part of your job!!
Anyway Tony, my task for today is to:
1) Check how to remove the heat exchanger (i have a PDF of the boiler)
2) Clean the bugger out as i reckon your bloody right and its gonna be like a 70s fondue set in there minus the sticks
3) Get it back together
4)Test and update this post with, i hope, a very big thank you!
But for the mean time, thanks for your post last night, well appreciate!!
