- Joined
- 27 Jan 2008
- Messages
- 25,028
- Reaction score
- 2,899
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Rule of thumb a welder gives out 25V at 25A plus another volt for every extra 25A.
So 100A at 13A, 125A at 16A, with a 175A needing a 23A supply.
Now the older sets also have a high inrush and spikes will rupture the fuse. But the newer sets with inverters are much smoother and some have some circuit to cut out when a rod sticks.
So although one can use a 150A inverter on a 13A fuse and often get away with it for the older types 100A is limit.
Over 175A twin or three phase is the norm.
The old Oxford oil cooled welders have in the main gone. There was the problem with PCB's in the oil. And second the earthing problem. The wires inside were un-insulated and if the unit is dropped they can bend and cause a short. This can connect the supply to output. So only safe way is to earth one of the outputs. However if this is done one can get welding current on the earth wires so the area where they are used needs 50mm earth wires to ensure they don't burn out. So normally hard wired so can't be used elsewhere. This has in the main resulted in the oil cooled welders being scraped.
Because DC gives a 25/75 split in heat and can use all three phases many commercial sets are now DC. It is also required for TIG and MIG. With the switch mode technology variable input voltages can be handled so one can get some really big sets. Air arc need around 300A and often one needs two sets to give output required and at 230V looking at a 50A supply for each set. Clearly these can't be used in a domestic premises.
In the older sets for example the BOC the iron core is racked in and out with an electric motor and if left in racked in mode often one can't switch them on without blowing the fuse. I have manually racked out the core many times.
The 16A supply in UK houses is a problem. The FCU is neat and easy to fit but the 13A fuse is just a little too low for many items from Ovens to Off peak heaters and includes welding sets.
With something like the welding set one wants the reset handy so the supply pods used with caravans are normally best option so the MCB in consumer unit is over the 16A.
However with the inrush often type C or D is required and this means often a problem with earth loop impedance. And of course this is a problem with DIY as very few DIY people have an earth loop impedance meter.
