Hello, I found this forum during an internet search to try and figure out what I should do about my boiler. Hopefully I'll be glad I did because a google search was useless.
When I came to check the pressure of my boiler it was on 1 bar so I figured id add a little water to the system and take it up to the recommended 1.5, when I opened the valve to allow water into the system I couldnt hear the usual noise I hear when I do this and the pressure stayed where it was, I turned the water inlet valve off and a drip began to fall from the right hand side of the boiler, around where the inlet pipe is mounted. After a while the dripping stopped, being stupid I tried it again a couple of times last night (as if somehow a couple of hours would remedy the problem ) to no avail. This morning the pressure reads 3 and the inlet still doesnt work, there has been some dripping in the night but I cant locate where it has come from. Ive spent the morning reading the manual and searching the internet but I havent found anything that even resembles useful, can anyone help?
thanks
db
thanks
db
