I have moved into a house with a Potterton Lynx 2 Combi Boiler connected with 2 wires to an old wall mounted room stat located in the coldest part of the house. I would like to move this and think that the simpliest way would be to disconnect this and install a new wireless room stat that I can take into the front room.
I have been looking at either a Siemens RDH10RF or a Drayton Digistat RF. Both of these seem to have the same basic wiring connections into the SCR:
L - live
N - neutral
1 - common
2 - heating satisfied
3 - call for heat
Connections 1,2 and 3 are the switch control and the diagram shows connections into the boiler control from 1 and 3.
My question is that on the boiler control for the thermostat there are 4 connections.
SWL - switch live
L - live
N - neutral
Earth
I understand that for these stats you dont need to connect the earth and obviously the live and neutral connect to each other, but where do connections 1 and 2 run to, I seem to be a wire short?
I'm sure theres a simple answer to this and hope someone can put me out of my misery
Thanks in advance,
Tony.
L - live
N - neutral
1 - common
3 - call for heat
SWL - switch live
L - live
N - neutral
Earth
Thanks in advance,
Tony.
