A
Alarm
I suggest you re read, POXY was used with other words like "Other panels have these outputs anyway" as in no need for relays and PSU`s.
FYI in terms of DB outputs it is POXY compared to a lot of others also.
Remember also a 10db increase is double in sound perceived.
Although 85db prolonged will cause deafness.
And I`m not likely to be locked in with one and if I was it would be turned off rapidly.
If you want loud try this, http://www.klaxonsignals.com/images/Products/docs/datasheet/369.pdf . Put 5 around the house.
I have one running 12 of these, fun when testing I can assure you.
