- Joined
- 14 Mar 2005
- Messages
- 5,777
- Reaction score
- 30
- Country
Have a good look at it first..if you dont think theres any damp then you could, if you wanted give it a slightly thinned coat of oil based primer sealer, alkali resisting is the best one...
If there is a problem with the plaster being smooth that should sort it...im not convinced about PVA and im sure ive read on here somewhere about someone doing it and the paint coming off after..
Either that or try re painting a small area first and see how it holds..dont rub the plaster down you'l scratch it to bits..
to get the rest off...a filling knife might do it...the blade is thinner and more able to get under the paint.
