Just bought a house that is 160 years old. the gable end brick wall has been rendered externally and there is an injected damp proof. Internally, the wall has been covered with cladding for decades!
So basically they damp proofed the outside but did nothing to eradicate the problem inside. Just left it, as it was hidden anyway it was deemed not a problem i suppose.
The bricks actually look and feel damp low down on the wall.
There is no ventilation or heating in the hall (where the wall is). would having a radiator put in there help to keep it dry and would it be an idea to get a de humidifier in before plastering?
I have taken all the cladding off and the plaster is falling off the wall in places, others it is not too bad. the top half plaster has cracked and is bulging in places.
I am thinking the best way forward is probably to take all the plaster off and start again.
should the damp still be an issue as there has been work done externally?
have left a fan heater in there for a day just to make sure it is dry
should i then render with a normal sand/cement mix?
how many coats and how thick should each coat be?
should i use a special plaster?
Can i dot and dab?
Can i dot and dab?
