Hi, I wondered if anyone could help me decipher 2 builders quotes we've had for some rendering work. We have an old victorian house with cracked rendering - we've had 2 quotes that vary quite a lot in price. I'd like to know if they are quoting for the same thing or not, but don't understand the terms used!
1 is proposing:hacking off render, fix mesh over cracks, apply dub out coat & 2 coats of waterproof render. From quoins or beads with stainless steel trims.
The other is quoting: Hacking off render, expose cracks, remove cast iron fittings. Apply SBR slurry mix, apply scratch coat of render 3 in 1, sand+cement with sika waterproofer. Apply bell drips, coin beads as required.
I don't understand most of those terms - are they basically quoting for the same thing, or is there any reason one of these plans is better than the other?
Thanks!
Thanks!
