NB You may be OK with PD despite your bay; particularly because the angle of the walls appear to be more rearward than sidewards (can you measure the angle?).
I had an application for CoL for PD approved that included the following:
Page 23 of the Government’s Technical Guidance states “A wall forming a side elevation of a house will be any wall that cannot be identified as being a front wall or a rear wall. Houses will often have more than two side elevation walls”. The example diagram in the Technical Guidance that follows this advice shows a dwelling with a very distinct staggered footprint. The existing bay window is very different to this.
Having regard to the advice on page 23 of the Technical Guidance, the bay window is clearly identifiable as part of the rear wall forming the rear elevation of the dwellinghouse. It is therefore not “a wall forming a side elevation of a house”. The bay window feature has a shallow depth and represents an architectural feature of the rear wall. It forms an integral part of the rear elevation of the original dwelling, providing articulation to this part of the dwelling.
