Hi all,
Just received the survey report on a house I'm thinking of buying. Would appreciate an explanation of a couple of things please
1) "The threshold detail at the junction between the dining room and conservatory and also between the conservatory and outside require upgrading at the junction with the floor edge". (Category 3 fault)
I'm guessing there is a problem where the conservatory joins the house at floor level and this could possibly let in damp?
The conservatory apparently still has 2 years left on its warranty so maybe this is covered?
I think I need to call in an expert - would that be a general builder?
2) "Penetrating dampness is affecting the floor adjacent to the shower cubicle within the bathroom. I suspect this is due to spillage/leakage when the shower is used. Concealed timbers may be defective and the adjacent floor should be opened up and fully investigated" (Category 3 fault)
The surveyor detected a patch of kitchen ceiling underneath the bathroom has been repaired due to water damage.
This sounds like it could be bad. Call in a plumber / builder to assess the damage? Is this likely to be DIY-able?
3) "Attic space has been partly converted including installation of a staircase together with some strengthening of the floor structure and alteration to the roof supports. The roof structure is serving its purpose satisfactorily however the alteration works do not comply with the current Building Regulations in respect of conversion to a habitable room (especially in respect of means of escape in case of fire). (Category 3 fault)
This is a DIY loft conversion with some strengthening work carried out. I doubt planning permission was obtained for any of it but I'm not too bothered about that. Would there likely be a problem with buildings insurance if the work was not done properly?
Thanks for any advice,
Isley
Isley
