- Joined
- 16 Sep 2007
- Messages
- 1,908
- Reaction score
- 163
- Country
I know this is an old topic but I've only just joined! I bought and fitted a Candy induction hob but it was badly affected by heat from the conventional single oven beneath. If the oven was on, the heating zones would signal that they were too hot (and unavailable for cooking) even before any attempt was made to use them.
Perhaps the oven was at fault, and was poorly insulated causing excessive heat to escape. But I disagree with flameport that they are useless. You can boil a pan of water in 40 seconds flat, and maintain a lower level heat than you can with a gas hob which is ideal for steam cooking rice etc. and are so much easier to keep looking pristine!
Everything has an operating temperature range, and external influences will affect it's operation. Try operating an LCD television in freezing conditions or a gas hob with a strong through draft!
