Hi, I've just joined this DIY network to ask for help - thank you! We have a set of spotlights in our kitchen (the kind set on a bar screwed into the ceiling). There are three lights and the middle one has gone out. It didn't trip the fuse switch or anything when it went. We thought it was the bulb that had gone and got a replacement, but it still doesn't work (have tried swapping the bulbs around etc). Is there a fuse or anything inside each individual light fitting that I can check to see if it has blown, or is the light fitting beyond repair? Its the kind with an outer shade for each bulb - which is the large spotlight kind that you screw into the fitting. Any tips appreciated - thank you!
