Spotlights blowing fuse
If the fittings have been covered with insulation it is quite possible the cables have melted & shorted together.
You're right. Checking the lights, I found that the insulation around 2 wires had melted. Luckily there was enough length to cut out the bad bit and rewire. Problem solved!
